NobodySpecial
I recently performed a front and rear tire service on my 2004 ST.
The previous tires - Pirelli Angel GT - were super duper worn and very done, and I put on a pair of tires that the PO sent with the bike - Shinko Verge 011. I had a local shop that has a good reputation do the tire mount and balance, etc. I got new valve stems, too. While there, I cleaned the brake pistons and replaced the ALOC bolt and rear pads with Honda OEM. I very carefully (four times now!) have followed the manual for sequence and torque values for the front, and I'm confident I did the rear in the right sequence (ALOC bolt first, then axle torque).
Here is the issue: whether decelerating or not, regardless of gear, I get head shake at low speeds. It's bad enough that I wouldn't want to take my hands off the bars, from 45 indicated and slowing to 43 or 42. Above that speed, I'm not sure I can feel anything and the bike is smooth as glass (up to around the maximum posted limits around here - 70/75 mph). Below 40mph the head shake disappears but I still think I can feel something in the bars.
I've re-done the torque sequence for the front at least four times, sometimes loosening and retorquing the front axle as well (in sequence). No change.
I've got maybe 300 miles on the tires.
The steering stem bearings feel excellent - no play, no notchiness, nada.
45K miles on bike.
It may be worth noting that when I first took the bike out after my service, the rear brake "pulsed" - I chalked that up to maybe an accidental greasy fingerprint or thumbprint on the disk brakes and new pads. It's largely disappeared, but I can maybe feel something in the rear brake.
I've read that others have had this issue with these tires, but I'd really like to rule out some mistake I've made first.
45K miles on bike.
