Here's what I do know. The stamped 8 digit number (on the top side of battery)is not a date code. There was a weak screened "MA1948" on top of my battery, this is the date manufactured.
I contacted Yuasa and they would not share the code system with me but they did offer to tell me the date of manufacture if I gave them the the code from the top.
So, MA1948 - translation: May of 2008.
I don't see the pattern on the translation from 1948 to 2008. I am trying to date my YUASA battery because it may be the cause of the problem with the instrument panel not showing the entire digits (see picture below).
If the bike isn't doing anything else unusual, I doubt very much that the battery is the cause of that problem.
As other have suggested in the thread about your missing digits, you've probably lost a couple of the lines that select those parts of the display. LEDs and LCDs like that are typically multiplexed to keep the pin count down and each segment is addressed by section and segment.
--Mark
Mark, do you know if the missing LCD can be repaired? If it can; do you know where to get it fixed? If not; I'll have to fork out 7 bills for a new one.
Bob, you posted you are having the same issue; if you're referring to the missing LCD; did the new battery fixed the problem?
Thanks guys! I really appreciate your input and recommendation.
Steve.
Cynical old me says maybe a less than scrupulous seller removed the label?Edit. So does my battery have such a label ? No it does not.
Maybe it was on the box ??
I'm completing the purchase of hearing aids. While this is completely another subject, the lack of professionalism I found locally at 4 hearing centers from 'Doctors' of Audiology (I visited 5) is staggering. I'll be posting about that in the near future.
