Yellow junction box
australia
Hello all.Can anybody point me to the right location of the yellow junction box where the black/white striped power wires join up.I have removed the entire air intake setup with no joy.Under the headlamp unit I found a yellow box…terminus ,but it was full of green wires ! There is a photo from Ian in South Africa dated Oct 11,2021 showing the item.Mine is an 08 model so it may differ from earlier models. I am chasing a lack of continiuity between the black/white striped power wire exiting the engine cut out relay/ bank relay and the fuel cut out relay Thanks.
It's under the PAIR solenoid which, according to the blurb, you'll need to remove...
There's 2 Joint Connectors located there, a Pink Ground Connector and the Yellow Power Connector wrapped up in tape.
@canada_67 - I've never come across it when I have been fiddling around under the fairing- so I have just been looking through some photos with the airbox off - is it / are they - that taped up block on the lower right of this picture ? down and right of the open brass tube connector on the PAIR solenid ? Photo taken looking under the airbox from the left hand side of the bike.
John, yes, the PAIR solenoid is on the right of your photo which can be removed to get better access, the Joint Connectors are wrapped up below...
Be careful with that box cutter (USA) / Stanley knife (UK)!!
Useful photo by the way!!
I never even noticed it when I had the PAIR solenoid disconnected - and I don't think I've ever seen a photo with it identified like that.
I've seen a multi-way yellow connector somewhere behind the headlamp fairing / screen adjuster and I thought - so that is where it is. Except it had the wrong colour wires going into it. So all that told me is that there are two yellow connectors.
I don't need the info right now - but it will sure be stored away for future reference. And @richie will find it useful.
Many thanks for the info - and for the red circle ?
