Wiring a heated Corbin Seat?
Houston, Tx
2003 ST1300
Anybody running a heated Corbin Seat?
Corbin sells a wiring harness for it that ties back into the fuse box, as per their attached instructions.
The seat draws about 4 amps.
Is there a reason it couldn't be fed directly from a Fuse Box switched outlet, instead of this Corbin dedicated harness?
  • Heated Corbin Seat.pdf
No reason at all except to make more money for Corbin, as long wire/fuse capacities are not exceeded.
I have the Corbin heated seat and use their harness. Never had an issue with it. Works a treat still after many many years.
I am sure their harness works, But I don't see the need for it if you can go straight into a fused switched outlet on a Fuse Box?
I am sure their harness work, But I don't see the need for it if you can go straight into a fused switched outlet on a Fuse Box?
That's a fair comment. However when I bought it way back when I didn’t have the service manual so I just did what they said. It’s fused and works fine. Never an issue.
FYI, I also installed a 12v cigar lighter socket in the left glove box at the same time. Works a treat. Also added powerlet sockets on the left too for heated vests etc. Use that for my trickle charge too! These are direct to the battery (via fuses). I wanted this so that I could charge stuff when the bike was stopped/parked. My cigar socket lives inside the glove box so I can stash whichever device I want to be charged in there and lock it away.
I had one for many years (actually, I still have it, but its a bit naked). I never got the instructions with it, I wired it to a 5 amp fuse in a separate wiring harness that I made for all my accessories. The fuse blew twice in all of the time that I had it. I later catered for a 7.5 Amp fuse. Always have it turning on/off with ignition and through a relay (but all of my acccessories are powered through one of two relays - one on with ignition, one on with accessories and ignition.
This diagram - post #24 - may help you to work out where the spare capacity is in the fuse box. Bear in mind this is a UK model - there will be differences.
Good to hear it can work fine without the Corbin dedicated harness, also about the 7.5 A fuse. Thank you.
The seat I am looking at is for single rider, was yours dual?
Planning to connect into a Fuse Box (relayed switched) pigtailed to the battery.
Just in case you are wondering about the Corbin seat. I have the Corbin smuggler too. Love this set up for 1-up riding since I get a little back rest.
Ah - yes it was - so a 5A fuse will be plenty big enough. The installed wiring controls the heat electronically, and it has a sensor in the wiring which knocks the power off if the seat gets too hot.
My black box packed in after about 120,000 miles of use, so I just joined the front and rear loops and attached it to a relay to the switch on the side of the seat. That worked just as well - but it would have been far too hot if I had connected the two loops in parallel.
The little black box is probably easy to make. I assume there’s a thermistor in the seat to measure temperature. A regulator and a comparator (temp on one terminal and potential divider on other terminal with a FET on the output to switch the seat on/off would do it). If you have a picture of the inside of the black box I might be able to reverse engineer it if need be.
........The installed wiring controls the heat electronically, and it has a sensor in the wiring which knocks the power off if the seat gets too hot.....
Was wondering about how they were controlling the heat. Thanks.
I have another heated seat with a controller built into the harness, but didn't see such thing on the Corbin seat pigtail, hence my wondering if I absolutely had to have the ($50 + shipping) Corbin Harness for control. Good to know I don't!
Good to know.
@MidLife many thanks for manual shared. I've powered my used Corbin under it and things working just fine. Tested while today ride +8°C and 140km/h top speed.
Passenger seat was re-cased to fit style.
Although I do have a Heated Corbin, I've never used it. It came on one of the bikes I bought.
However, I do have a heated RDL and I hooked it through a "Heated Gear" thermostat controller, so I can control how much heat gets to it. The Controller is a dial type, like you would hook up to a heated vest or gloves. And that hooks up to your battery or like in my case, my fuseblock.
The single operates the saddle heat and the double operates my gloves and liner.
And BTW, I remove them when the weather doesn't require heated gear.
