Working on my project list, so far I have switches to clean/lube, ground point and connector and rear wheel shaft/final drive hydraulic noise damper if there is such a thing, I need to do some reading here. Basically, if I rotate wheel back and forth I hear a noise that I don't have on my other shafters. I didn't see a hydraulic damper (as a part of the shaft) when I had the bike apart in spring.
Edit 1 - adding the brake fluid flush (clutch and brake), the fluid in the clutch reservoir is murky, probably from not flushing the lines good enough in spring when I worked on it. Fluid in brake reservoir is clear, I flushed that circuit to death.
Edit 2 - added coolant replacement, should have done it in spring.
What are your winter projects?
