Hi All,
I wanted to share my recent installation of the vista cruise throttle lock. I should have looked more closely to the previous posts here, as I would have gotten some better ideas, but I didn't, so I ended up re-inventing the wheel a bit. Anyway, here you go:
I used this throttle lock on my previous bike, an SW-T400 and I loved it. Though on that bike it was much less involved to get it installed.
I hope it is useful to someone and good luck.
- I got the Vista Cruise Control for motorcycles from Amazon (photo attached).
- Like others have mentioned, you need file the inside of the throttle lock to fit around throttle tube. It seems the throttle tube on the ST is larger than 7/8s. Only a slight sanding was needed. Be careful and test it multiple times.
- I chose to keep the retaining foot intact and instead drilled and tapped a 6mm hole on the bottom of the throttle housing (see photo)
- I had to "pull" the throttle grip slightly off (not completely off) so there was enough room between the throttle housing, throttle lock, throttle lock washer, and grip flange (in the photo you'll see I also trimmed the flange, but it was not necessary. I could have left that alone).
- The additional width of the throttle lock pushes the throttle tube enough that when you re-install the bar-end, it binds. So I just cut off the lip at the end of the grip.
