Big_Jim59
Are oil changes all like Murphy's Law? If you are going to drain the oil you will make a mess.
I was prepared, like I always am. I had the proper tools, the proper drain pan, rags, paper towels, oil filter wrench (that works in the tight confines of the ST1300) and I was equipped with the calm and focus of a Buddhist monk. What could go wrong? I pulled the oil filter first and let it dribble before spinning it off. I spun the new on on. I pulled the drain plug and emptied the bottom end. Here is were my best laid plans ran amuck. I have this nifty funnel that looks like a measuring cup. It has the graduated measurements built in and you can fill it, one quart at a time, then turn the spigot on and you can flow that measured quart into the engine. This was working great until I lost my focus. I had not shut the valve all the way. I was pouring in another measured quart and noticed that I was pouring fresh oil down the side of the engine!
I was doing so well.
