Has anyone switched from one type to the other and what did you notice about the handling, tire life, etc?
The first/major things I noted with radials installed:
- indirect front feedback
- harsh ride, every single crack or step in the road bounces really hard
- bike won't hold a straight course, always drifting left/right/all over the lane...
- tires creep up/catch on longitudinal grooves/unevenness, be it white-lines, tar-snakes, truck rooves, the tires lock onto them...
- tendency to noticeable dec wobble...
- don't like to lean, you need to literally hulk the bike into a corner and then fight that it stays down... (kinda "added character"...)
- quite inaccurate handling while leaned, don't like load changes (even thinking on applying brakes lead the bike to violently pop vertical), never exit at the point you'd aimed at...
- a narrow safety margin while leaned with almost
no pre-warning... hold... hold... hold... BAM! Rear slides out...
- about only half the mileage/live-span (which is the final no-go; no place for tires that won't even last for 6000km/3750miles on a long distance tourer...)
Now a look on those oh-so-old-style bias/ply Exedras:
- very precise steering
- comfy ride, tires absorb a lot on crappy roads
- high stability in running straight, one can actually take both hands of the bars at 100mph, light a cigarette, sip a RedBull, etc...
- almost completely ignores/absorbs any longitudinal influences, not even asphalt milling (done to reduce car aquaplaning) will be noticed...
- barely any dec wobble, their build really precise, didn't need to relocate and balance weights for a couple of years now...
- very agile, bike leans over with no effort...
- total precise handling, very neutral on load changes, applying brakes has at most only minimal effect on leaning angle/handling in corners...
- a wide, nice envelope with gentle warning during which front and rear slowly start to drift outward
equally...
- a proper live-span of 10~12,000km/6000~7500miles, hence suitable for touring for 3 weeks and then some...
The selection on 110/80 R18 TL 58 W (front) is quite limited though...
T31 or T32 might work, but won't have the live-span of a G547 by far...
