Article [13] ST1300 - FI Codes (MIL) Malfunction Indicator Lamp
Admin-dude
009754
The PGM-FI MIL denotes the failure codes (the number of blinks from 0 thru 33).
When the indicator lights for 1.3 seconds it is equivalent to 10 blinks.
When more than one failure occurs, the MIL shows the blinks in order of lowest to highest number.
Code Reset:
  • Turn the engine stop switch to the RUN position.
  • Turn the ignition off.
  • Using a jumper, short the brown and green/orange wires on the diagnostic connector.
  • Turn the ignition on.
  • Remove the jumper from the diagnostic connector.
  • When the FI indicator lights, immediately short the brown and green/orange wires on the diagnostic connector.
  • Verify that the FI indicator goes off and then begins blinking.
Excellent information. Ty
Mellow this steathtourer I started the ga a few years ago.got hit on my st so I was gone for a while buy I'm back. I PICKED UP ANOTHER 06 which has a intermittent f1 light I can hit the kill switch then turn it back on going down the road and blip the throttle and it goes out.can you you give me some idea of where to look
First thing that you need to do is determine what fault code is being triggered. The fault code will determine the diagnostic path that will need to be followed.
Have a look at the links in the below thread to get started.
Code Reset:
Just bought an '06. Great info. Thank you! /r Brad
