ST1300 Crankcase Breather Plate/Gasket?
canada_67
Epsom, UK
ST1300-A6
Hi,
Just looking at the workshop manual as the valve clearances are long overdue, have found reference to the crankcase breather plate and gasket. Manual states the gasket should be replaced, presumably if the breather plate is removed...
However, I cannot find mention of the breather plate on any parts fiche, I'm guessing that the gasket replacement is probably overkill but regardless, where's/what's the part number for the gasket?
Cheers n'beers.
  • Scan 1 Nov 2024.pdf
Going by the photo, looks like a paper/fabric gasket of some kind that goes behind the crankcase breather plate, not the rubber mounding that fit around the spark plug apertures...
hmm, seems to be a "non serviceable" item, not even the gasket kits list that plate...
But its OEM fitted to the cover:
Great photo!!
Manual implies the plate is removable with a gasket behind, as you say no mention of the plate, or the gasket, anywhere I can see...
