The curse of the new season is upon me!!!!
MOT test was booked for Monday so thought I would fire up the beast, which has been sitting since December, and check it over.
It wont start!! Turns over no probs and got a spark. Dont have 12v to the fuel pump though. All fuses and relays ok, kill switch ok as its turning over. No FI light when the ignition comes on and no flashes when its turning over.
Any ideas? Only the ECU, bank angle sensor and wiring to go. No signs of mice damage or corrosion as its in my garage where it normally gets TLC. Its not the fuel pump as it runs if I fire 12v direct to it. The battery is on a tender and turned it over for ages before slowing. A fresh battery gave the same symptoms. Can't be the Kill switch or sidestand as its turning over. Activate the kill switch and it doesnt turn over. There is no alarm on it or any other additions.
Any suggestions would be appreciated for resuming the chore tomorrow.
It was last run in early jan, no probs, and has had a fuel stabaliser in it as well. Hope its not the ECU!!
Its a standard UK spec 2004. Ive searched other posts but dont see all of the symptoms above.
Many Thanks in anticipation.
