ak85lp
(Paul)
I recently had the problem where the bike shut off under high speed and would start up on the side of the road after a bit of a break. I replaced the fuel filter which did not solve the problem. After doing some searching here I found it could be the fuel shutoff diaphragm. I ordered the K&L kit and took things apart this morning. The bigger rubber diaphragm had about a 1/4 long tear in it.
As I'm taking it apart the spring fell right out and now I can't figure out how it goes back together. I read the report at this link but without pics I'm kinda lost.. https://www.st-owners.com/forums/showthread.php?1711-ST1100-Fuel-Shutoff-Repair
I understand how the 2 rubber diaphragms fit together with the small metal piece inside. Does the spring sit in the recessed hole in the piece that has all the tubing ports or does it side inside the two halves that go together before you place it on the ported piece? I think the latter is right as the spring seems to sit better in the flatter piece. The only thing with this is that the spring sits against the bigger diaphragm directly.
Hard to explain I know. Here are some pics below as to how it might go together 2 different ways.
