D_W_L
aka, DL-ST95
My handlebars bind slightly when turning right, so after taking a look, it seems that the problem might be the routing of the throttle cables. As you will notice, the cables are routed on the outside of the air filter skirt. Is this correct? It looks like they could be routed on the inside of the skirt which would/could create a bit of needed slack. Does anyone know what the proper routing should be. Thanks.
