I've got a 1998 ST1100AW. A few weeks ago I was out on the bike and it seemed the battery didn't have too much puff left. About 100 miles from home I had to fill up with fuel and needed to jump start it. Riding home in the dark the lights were getting dimmer and dimmer, until after about 75 miles you could barely see them. I decided to pull off the road, and as I switched on the indicator the bike just died. Stopped to find the battery virtually flat. Got recovered home, thinking regulator/rectifier fault. Put the battery on slow charge, and after a couple of days came back to it. Checked all the easily reachable wiring, fuses etc, cleaning where necessary. Bike ran okay but voltage checks showed I still had a problem. Took it apart again and fully charged the battery, then along came Christmas and everything stopped! Today, after a couple of weeks, I returned to it. Battery had been standing, off-charge and off the bike, for about 10 days and was showing 12.8V. The bike cranked sluggishly at first, and fired up after about 5 seconds. Running at about 2000rpm the voltage across the battery was 14.2V - I think a reasonable charge. Switched on sidelights, dropped to 13.4V initially before crawling back up to 14.2V. Switch on headlights and the charge voltage dropped to around 12.8V and stayed there, even on revving to 5000. Lights off again - 14.2V. Found that whatever extra I switched on dropped the voltage, and the headlights' additional 9 amps was enough to kill any charge.
Battery does seem to hold a charge OK, but it is the same Yuasa battery that was 'not new' when I bought the bike 7 years ago! Now I'm not sure if its R/R or not - hope not, now that I've found that it's built into the alternator - expensive and a pig to get to! There is some corrosion in some of the wiring (bikes had a hard life - in use all year round), but all the connections I can get to seem clean enough. Could it be mucky connection dropping the voltage,or is it more likely to be Reg/rect, alternator or battery? Clearly I don't want to strip out the alternator and pay a fortune for a replacement just to find it needed a new battery! I've noticed some others have had broadly similar problems, how did they cure it? Any ideas?
