Clayshooter08
Looking to see if it's been done and how??? What tank and where did you tap into fuel system???
But they will not guarantee the volume. The 11.5 gallon Stock plus Aux is a hard and fast rule. There are horror stories about being over capacity. Certification rides you can use whatever wild ass set up you want.I would also do a google search.
Boyd's Welding in Ocala, Fl. will make one to your size.
#1 Source for Custom Aluminum Tanks and Accessories
High quality custom aluminum tanks, tank parts and accessories for any tank application.fueltankparts.com
I'm not clear how one grounds a non-metallic, non conductive tank. Maybe @Larry Fine has some ideas? Would tying the plastic tank to the motorcycle with nylon rope fulfill this requirement?19 Non-metallic auxiliary tanks should be grounded to the frame of the motorcycle with a conductive strap or wire attached to the tank in the vicinity of the fuel inlet. Metal tanks do not require a grounding strap if they are attached to the frame with conductive brackets.
Plastic can be conductive to static electricity. A drain wire would be a more accurate term.I'm not clear how one grounds a non-metallic, non conductive tank. Maybe @Larry Fine has some ideas?
While something like a copper screen formed into a cylinder and inserted into the filler tube (and grounded to the frame) might mitigate static charges, you cannot ground a nonconductive tank. If the material is non-metallic and is conductive (say carbon fiber and epoxy), then it is a different story. And, I disagree, plastic does not conduct static electricity, though we might be arguing semantics here.Plastic can be conductive to static electricity. A drain wire would be a more accurate term.
It is long been advised to remove portable metal & plastic gas containers from vehicles and set them on the ground before filling. The reason seems to be because flowing gasoline tends to build up static electricity and plastic or rubber underneath the container prevents the static charge from passing into the ground. With no easy path to ground the static electricity goes to ground through a spark to the pump nozzle igniting the fuel. Metal containers are most at risk but plastic containers have also caused fires.While something like a copper screen formed into a cylinder and inserted into the filler tube (and grounded to the frame) might mitigate static charges, you cannot ground a nonconductive tank. If the material is non-metallic and is conductive (say carbon fiber and epoxy), then it is a different story. And, I disagree, plastic does not conduct static electricity, though we might be arguing semantics here.
And I agree, conducting is the wrong term.And, I disagree, plastic does not conduct static electricity, though we might be arguing semantics here.
They will make the tank to your print. I would think they could "engineer" the tank to be a specific volume and standards if you wanted to pay for that service.But they will not guarantee the volume. The 11.5 gallon Stock plus Aux is a hard and fast rule. There are horror stories about being over capacity. Certification rides you can use whatever wild ass set up you want.
Ron, they CAN do it and I'm sure that if you give them accurate plans you'll get what you asked for -- but they still won't guarantee the volume. If you're over the limit you are over. Now you're sad.They will make the tank to your print. I would think they could "engineer" the tank to be a specific volume and standards if you wanted to pay for that service.
Would you what data source they use by any chance? Would a person be safe if, for a Honda, they go by what volume is listed in the Honda Service Manual? Or is it possible that they use some other source that potentially could be different?Also, note that the IBR accepts whatever the manufacturer says the stock fuel capacity is. Honda changed that number around 2007. It was 7.2 gallons from 7.6. I can't tell that they actually changed the bike but if you build an aux tank using the 7.2 number and find out later that you have a year rated at 7.6 you'll be sorry yet aga
I know that they use the manufacturers number (spec). I don't know what source they use, but it may be the service manual.Would you what data source they use by any chance? Would a person be safe if, for a Honda, they go by what volume is listed in the Honda Service Manual? Or is it possible that they use some other source that potentially could be different?
Didn't I see, in the posted IBR pictures, their officials measuring the fuel poured into the tanks? Or was that just the auxiliary tanks?I know that they use the manufacturers number (spec). I don't know what source they use, but it may be the service manual.
They do not measure the stock tanks, just take the manufacturers word for it. It takes a whole chemistry set to measure the aux tank volume and includes invocation of specific gravity among other things. To me, specific gravity is when I hit the pavement. Very specific form of gravity. But my tank passed and they rated it as holding less fuel than I thought it did. I was .2 gal under the limit.Didn't I see, in the posted IBR pictures, their officials measuring the fuel poured into the tanks? Or was that just the auxiliary tanks?
