Shinko tire
New jersey
St1300PA
just put a shinko raven on the rear , always ran pirellis and I have to say this tire feels great , at slower speed around turns the bike feels lighter , ill get back when mileage gets higher.
I had high hopes for a Shinko Raven 09 I put on the back of my NC. Some others were getting pretty good mileage out of them, but for me it turned out to be the worst of 5 different tires I've tried. No complaints on handling, just didn't last as I had hoped, getting 6478 miles before it was toast. I was hoping for more than 7500. The price was certainly a good point.
Hope you have better luck.
I got over 13k-miles out of Raven 009 on my VFR. One main cause of low-mileage is over-inflation. Manual's recommendation is just corporate CYA to protect tyre manufacturers. Sure you'll never overload tyre at max-psi, but you'll lose lots of mileage and traction due to eeny-tiny contact patch. But you'll never be able to sue tyre-manufacturer because you'll have crashed and died due to no grip. Cops will just write it up as "biker going too fast for conditions". Which is actually true since you had much less grip at max-pressure.
BTW - max-psi listed on tyre is for max-load at tyre's rating for 1-hr at it's max-speed without unsafe temperature-rise (typically +195F limit). So that means 536 + 805 = 1341 lbs load on those tyres going 168mph for 1-hr!!! :eek: Unless you are doing that, there's absolutely zero need to inflate to max-pressure. I don't even think our bikes can go that fast, much less for 1-hr straight.
I used to run 34-36/36-38 on my ST because that’s what Michelin recommended back in the mid 2000s for the ST1300 but I couldn’t get relatively even wear or mileage past 6000 miles on a set of tires until I increased pressures to 38-40/40-42. No problem with grip and traction at those pressures. Michelin, Metzeler, Bridgestone I ran them all on that bike. Two track days on my ST running 30/34 cold.
That looks like you ran over a sharp piece of metal (can) etc.
I had that same cut on a brand new Pirelli rear tire after only a couple hundred miles.
In that case I would look further into the crack to see if cords are cut.
Lets hope they warranty it.
I tried the 009 Raven rear didn't care for it. Bike did not turn well with it on, too flat in the middle of the profile. Felt like a tire I had done 5000 straight highway miles on even when it was new. Maybe just me, I took it off after a few weeks.
What is the 4 digit date code? The cracks down in the sipes look like dry rot.
3823
This tire came through Amazon from powersports911, I waiting to hear back from them, not holding my breath though.
Somebody sold a defective tire that was returned on Amazon……
I agree looks like dry rot, or ridden with low tire pressure.
