kiltman
Bit of a frustrating day. My newly installed Rostra Cruise will not engage.
I have a Goldwing 1500 cruise control switch.
I have a wheel sensor kit from my Audiovox CC100. Using three magnets
I have gone through the self diagnostic testing procedure from the manual.
After putting it in test mode, the brakes activate the test light
The resume/Acc button activates the test light when activated
The Set/deacc button activates the test light when activated
When I spin the rear wheel it activates the test light and it does a constant flash
When engine is running the test light flashing mode speeds up when applying throttle.
I have power at the 4 amp fuse and power at the 10amp fuse
I have tried different configurations from various install instructions from this site.
current dip settings are 1,3,8,10 are ON 2,4,5,6,7,9,11,12 OFF
I do not have any LED bulbs in the brake circuit
The Goldwing switch is considered an Open circuit control switch.
I phoned Rostra they think it might be the wheel sensor. (it should have a resistance of 40-50 ohms.) I can't get a good reading from it.
They suggested grounding the violet wire. ( I did that no change)
They suggested grounding the dark blue wire to the tach (I did that no change)
The Tupperware is off and I've been road testing engaging the system above 35mph, I can clearly see if the Rostra throttle cable were to engage, it does not.
Suggestions welcomed
