Pop-Pop
Trying to install 2” rizers. The throttle and brake cables are too tight. Is there a way to disconnect and reroute them? Im shocked they are so tight. I thought the rizers would “just pop on”!
Thanks. I already pulled one clamp off the brake line and think it will work. No, its the throttle brake handle cables. Tighter than me in a dollar store! I removed the air filter cover but the cables are tight to the filter housing. Was hoping i could re rout them over the filter cover but there is too much in the way and they r too tight.I assume you are talking about the brake lines and not cables. Check down on the front forks and see if there is a clamp sort of hidden away at the triple tree that you can loosen and get some slack. As far as the throttle cables go, you'll have to pull the tank 'shelter' and see if you can reroute them a little bit to gain some more slack.
A “ reverse bleet” what? Are you a surgeon?I think I routed mine behind the triple clamp when I did 1" risers. Then I put on heli bars and the brake line was just a tad too short but the rest were still okay with reroutes. FWIW, I just replaced the line from the master to the ABS module with a slightly longer braided line and did a reverse bleed with a syringe with great results. Yours being non-ABS (I think?) should be as easy or even easier if you get a longer hose.
When I replaced the OEM risers with taller ones under the Helibars, I relocated all of my cables, wires, and hoses to behind the upper triple clamp without removing any body parts or accessing the bottom end of anything. I was able to pass both master cylinders through the fork tubes, and disconnect and reconnect the throttle and choke cables just at the handlebars.
Every time i try “scotching” i wake up with a major hang over!If you are 'careful', you can remove the top of the triple tree and route the cables as you like, IIRC.
It requires removing the big nut and loosening the fork allen bolts at the top - make sure you have the front forks 'scotched' so that they don't drop down.
That is a real good idea! Im trying again tomorrow after an eve of service manualling!When I experimented with 2" risers I removed the brake hose clamp on the fork tube between the upper and lower triple trees. Then there was more slack to be had at the hose clamp on the bottom of the lower triple tree. The throttle cables were routed around the outside of the air filter assembly. I ran then underneath it and had enough slack.
RT
Forget them.Whats funny is that im doing all this on the busy streets of boston and the meter maids really arent digging me! They growl and keep walking!
They are all overweight anyway!Forget them.
They're just jealous.
Doesn't make them bad people.......pokes midriff..........They are all overweight anyway!
Shade in the summer, warmth in the winter! But would I get a ticket if I fell asleep and neglected to feed her meter?Doesn't make them bad people.......pokes midriff..........
A reverse bleet is an "aaaaab!"A “ reverse bleet” what?
