Yeah, but as "the red haired STepchild" in here I juST didn't dare to respond...Did anyone else spit coffee on the keyboard when they saw his picture?
Vehicle troubles increase with both age and the complexity of the vehicle. We are especially at the mercy of all the little electronic decision makers in most every system on the bikes. Confounding that is the full dress suit on both our ST's. Some proportion of us never look there until there is a problem.....usually caused by not looking under her skirt. Don't clean it regularly enough? you will have corrosion related problems and surprise leaks from fuel, oil, water and vent hoses. Get a manual and DO the suggested inspections/maintenance mentioned on the little mileage schedule. Not criticizing anyone, I have good friends who don't care for working on bikes.....they simply trade them off much quicker than many of us do. As for me, I prefer long term relationships, keeping them 'til it just isn't practical for me to keep up with.I think if anyone is looking at an old bike, then they have to be prepared with the thought - if anything can go wrong, it probably has already - and I will ned to fix it.
I recently had that experience with my brother's bike. Told him I'd sort it for him. A1996 CBS/ABS/TCS ST1100. About 30K on the clock. It was OK for about 5,000 miles and then it wasn't.
Rear brake seriously dragging. Worked out what might be the problem and totted it up.
I was lucky to get away with 7 new pistons, full set of seals, new brake lever spring and circlip and a new split pin for the SMC linkage.
Talk about one problem leading to another. The brake pedal wasn't returning. The pivot 'bearing' was bone dry and corroded. A winter of riding later it was stuck on. Rear brake got hot, overheated, melted seals, wore pads down. On top of that the linkage in the SMC was not moving freely. I took it off and got it home - I couldn't move either of the pivots. The SMC itself was fine - just the pivot assembly. That poor rear pad didn't stand a chance.
A bit of TLC and got the pivot moving freely. I know how that goes together again - but it makes absolutley no sense when it is in your hand ! A bit of makeshift 'reaming' of the brake pedal shaft and 'bearing'. Standard clean up of calipers (which were remarkably gunge free), a pair of 2/3 used pads from my 1300 (same fit) and a dawn to dusk re-assembly job and refill and bleed and he was good to go. Except that his MOT had run out while it was in pieces. He got it booked in for a couple fo days later, so his first test ride was carried out en-route. Passed.
But I'm looking at it and thinking - this needs doing, that needs doing. I used to love my 1100s but I was always working on them. I quite enjoyed it - but I'm 18 years older now - I don't miss it.
Brevity ? No can do.My first thought was when you have Igofar and Jfheath both writing essay responses
Yea, it's funny how a supposedly frozen piston goes in when the brake hose is off.Did anyone else spit coffee on the keyboard when they saw his picture?
Bent guide dowel, displaced rubber grommet, what appears to be a damaged rear piston, and wait for it..........
what the heck is that rusty coiled spring on the pad retaining pin????
That picture speaks volumes about how someone (hopefully prior owner) knew absolutely nothing about the brake system, and was trying to jury rig stuff to keep the rear brake from locking up.
I'll bet anyone here a donut and a cup of coffee that the SMC on this bike is completely trashed as well.
Keeping fingers crossed that our OP won't try to ride the bike before its completely gone through and deemed safe.
You don't need a compressor, just put the brake hose back on and slowly pump the brake. When a piston is siezed badly compressed air sometimes doesn't work.Yep. I figured that out. I have the caliper off and now realize i need to go buy an air compressor. smdh. You think a 160PSI compressor will blow those pistons out?
And I really enjoyed the cheap purple Chinese brake pads from eBayYea, it's funny how a supposedly frozen piston goes in when the brake hose is off.![]()
Yes - probably. And I know that isn't a negative statement about him - you don't know what you don't know. It's a big step to take.What is sad, is this poor guy probably knows enough about brakes to think he’s right, but not enough to know that he’s wrong.
Its not enough to laugh at his predicament and mock his mechanical ability, but then you have to add that if he takes his bike to a shop, they're likely going to screw it up on him. (I think you may have forgotten your trademarkAnd I really enjoyed the cheap purple Chinese brake pads from eBay
He’s probably going to drop it off at a shop, where some young kid will damage it further because he’s never seen or worked on one.
