I had to remove the front fender to get the front wheel out. I did not have the back wheel off, and could not get the front of the bike high enough for the wheel to clear the fender. No big deal as I was pulling the forks to change springs and oil.
If you are going to do your own work, I would just go out and get a 1/2 drive 17mm hex bit. This bit fits the front axle as well as the fork caps. When I tighten the axle, I use the hex bit to keep the axle from turning while I tighten the axle nut. Then tighten the nut side pinch bolts, put weight on the front of the bike, and then tighten the other side pinch bolts. This was per the shop book.
