sirbike
Just curious, why would you need to make that?the only reason to get to the 14mm stopper bolt would be to remove the wheel, and you would have to move the muffler to do that.
Unless you’re trying to remove the rear caliper, then you would still need the 27mm for the axle nut.
And…..wait for it….you won’t be able to use your torque wrench![]()
Well, you'd still need to clean, inspect and lube that bolt...That stopper bolt backs out far enough with the muffler in place.
