I just noticed that my rear brake is dragging. Sigh. No Damage yet.
I have a 2004 ABS w ~ 70K miles that to my knowledge has not had any work done to the SMC….so I suppose I’m due for that….I suppose being in Arizona kept moisture out of there this long.
Starting noticing this the day after a tire change. I’m assuming that the shop could not have done anything to mess with the brakes during the tire change and am attributing it to coincidental timing. Maybe it was there before but didn't notice it then.
This is the link to the SMC Piston that I was intending to buy.
https://www.partzilla.com/product/honda/45620-MCS-G04?ref=583cf5d4acded83ee098cd742e9f7b7560bd72ae
Now to find a Brake bleeder. I’ve always been intimidated by this job……but I’ve read all the threads on here about it and my body is ready!
Thanks in Advance!!
- I understand that there was a change to the SMC starting ~ 2008 or so….and wanted to confirm if I needed to buy the old one or if the new 2008 version was a drop in replacement?
- Navigating around the Parts Fiche at I see multiple part options for a 2004 ABS and I’m not sure if all these parts are the same or if one was the old one and the other new ones? Any recommendations on whether my selection is correct?
- https://www.partzilla.com/catalog/honda/motorcycle/2004/st1300-a-st1300/left-front-brake-caliper
- Do I need to pop the pistons out and replace seals at the same time?
- I am unable to push the calipers in by hand to compress the pistons and don’t have a clamp that can fit on there while on the bike. Is there something else I should check before starting out on this job?
Thanks in Advance!!
