The first weekend in November, I finally got around to taking my (new to me) Unigo trailer out for a test trip. At first, I thought I was gonna get killed. Each time I approached 70mph, the bike/trailer combo went into a severe wobble.
I learned this was ALL my fault
Lesson #1 - Tire Pressure. Check tire pressure on all 3 tires BEFORE your trip. My pressure was low on all 3 tires. No wonder it wobbled so badly! I was also reminded that I need to get a right angle valve stem for the rear tire at a minimum. Getting a good seal on that rear tire to air it up can be difficult and aggravating.
Lesson #2 - Load Distribution. Load heavy things low in the Unigo. I had my duffel bag in a vertical diagonal in the trailer which meant the weight was low and high. Not such a great idea. The trailer rode better when I put the duffel on my back seat/tail rack and loaded the trailer heavy low, light high.
Lesson #3 - Dirty Air. Be careful of air fluctuations. Pulling this trailer, the ride is very sensitive to changes in air pressure. Dirty air from 18 wheelers is easy to handle on the ST. However, pulling the Unigo I noticed that I feel the air get dirty much further away from the vehicle than without the trailer behind, and it induces more wobble. In addition, I felt dirty air from larger 4 wheeled vehicles as well. Whereas without the trailer, I never did. There is a fine line between throttling through the air turbulence and just backing off. Mostly I powered through it, but only if I could do so keeping the speed below triple digits. Next...
Lesson #4 - Speed. Once I got the tire pressure right and the load distributed well, I had to see how the highway speeds were effected. I was advised to not go ever 90. Great advice!!! The wobble over 90 is almost as bad as when the tire pressure is low. But I had to test it.
Lesson #5 - Parking. Until I practice more, I take pull through spots with the trailer. The Unigo is so small and responsive that backing up to park can be tricky, for me at least.
Lesson #6 - Convenience. Ok, I never thought I would want a trailer with my bike or need one. But I have to admit, it is so darn convenient!! Having the Unigo removes the worry of where to put something you may acquire on a trip. It is also handy to open it up and toss in all the gear for me and my friends before we go into a restaurant. In my saddle bags I keep certain things that stay there. Such as tire repair kit, air compressor, extra shield, glove options, etc. So not having to rearrange the saddle bag stuff in order to fit my full face helmet in one side is pretty handy.
Lesson #7 - Visibility. I ordered Multivex mirrors. The Unigo has such a small profile that I could not see it in my mirrors. That is my excuse anyway.
Lesson #8 - Handling. With 3 wheels it does feel somewhat different. Grooved concrete, road snakes of liquid asphalt, bumps, etc... all these you do feel more. However, I think the Unigo does handle pretty seamlessly. It leans when the bike leans. Pretty neat. I simply thought of myself as being in a longer vehicle when passing and threading through traffic.
Lesson #9 - Removal. This lesson was taught to me. When removing the trailer or moving it by itself, use two hands ALWAYS. Since it has only one wheel, it can shift from side to side very easy. Dropping the trailer would not be cool. So use two hands all the time, one on the handle and one on the tow bar.
Admittedly, many of you have oodles more experience that I do pulling trailers and riding period. But I thought I would post this so someone could learn from my (ahem) ignorance.
The Unigo is the first trailer I have ever had, but it is a keeper. It will be going with me for many miles I am sure.
Questions?
Questions?
