THANKS! I saw that diagram but couldnt identify my part but will keep trying....That would be called a "maintenance cover" or "lid", found on the parts lists under "Lower Cowl"
This part didn't have the rivet and was taped down - It flew off at some point and I can't identify it.
.... I thought this part was made of unobtainium. There was a thread or two about modifying the mounting so the pin flying away didn't allow the lid to follow.
I came across that one somewhere but its missing the black.
The circled area in the pic refers to the missing pin. But he's referring to the lid.
That would be #10 for the right side according to Larry's link. But it looks to be different than the one in Braz'z pic. Or are my eyes deceiving me. It's early in the morning for me.
The link says "In stock". I thought this part was made of unobtainium. There was a thread or two about modifying the mounting so the pin flying away didn't allow the lid to follow. Routine checking of the pin's condition is a good idea.
I now see that the black might be an add on accessory per the post by Midlife - "That would be for the lid that comes with the optional stick-on deflectors."
Dude you Rock - Beers on me when I roll through Houston........Two different sets. The one mentioned above is a (very difficult to find) deflector that clings on the edges of the fairing and comes with its own replacement lid.
The one you have is a knee protector for the fairing, that tacks on the fairing itself and on top of the standard lid.
Depending on riding position, some riders find their knees rubbing and scuffing the fairing, hence this protector.
So a new standard lid will fit your bike, but will be missing the padding that was tacked on top of the one that flew off.
Here is the padding kit.
Correct, they are two separate pieces. The body-colored panel is the maintenance cover. The black plastic is a separate piece, part of the larger surrounding in a kit I presume to prevent one from scratching the cover. I don't know their part numbers.I came across that one somewhere but its missing the black.
YUP.....If you don’t want to loose those in the future, here is a better method.
Body molding clip and threaded fastener
YUP.....
