NobodySpecial
Greetings!
I'm about to do some maint. on my 2004 ST 1300A:
I own a front stand from these folks: https://www.pit-bull.com/
along with "pin #4" which they claim will fit this model.
It works by placing the "pin" in the steering stem tube and it brings the front into the air a good bit. It's off the centerstand (barely) and is balanced pretty well on the stand and the rear tire. I do have to move one of the brake lines out of the way a bit, but only a little bit and only to get the pin and collar past the lines. After that the brake line is under a little tension but not much.
Does anybody know of any reason why I should NOT use this? I plan on doing the work sometime this week, weather cooperating.
- clean up brake pistons and new brake pads front and back
- replace two O-rings in the back along with clean + replace moly goop
- I'm having a shop mount and balance the Shinko Verge 011 tires I have
