To my eye that's the best color for the ST.The all white bikes are pretty.
I agree with the others about the white. I really like it. I'm tempted to paint my 1100 this coming winter. And I'm planning on sticking to stock Honda colors just in case replacement parts are needed.
Wiring diagram for these shows, they are yellow only, white only, and power to both is white also. Shows them hooked to low headlight for yellow, high headlight for whiteUnless I'm wildly mistaken, you may have to switch that 1,2 combo. I have the Zmoon and if the yellow are powered there is no white. Switch 2 works with switch 1, if you flip your wires, 1 is white, 2 is yellow, that should solve the Zmoon wiring. IIRC...
For a couple dollars, you can go to autozone and pick up a couple small amber running lights (above the headlights).
No prob!Finally got around to hooking up the yellow fog function of these light, have them wired to the 1-2-3 switch, position 1 is yellow fog, position 2 is white running. Thanks again Nexus for posting the switch wiring photo
No, it's a $85 Chinese Amazon case, WAY better than I thought it was going to beNo prob!
Oooohhh! Is that an OEM top case? How'd you pull that one off? They are notoriously rare!
That's crazy! It looks like it was made for it! Awesome find!No, it's a $85 Chinese Amazon case, WAY better than I thought it was going to be
