Hi,
Does anyone know torque values for the oil pan bolts? I've looked in the manual and can't locate them.
Thank you!
Thank you!
Oh, didn't catch that.... yeah 6mm will eat it at 17 - 22 ft lbs. 10 is fairly typical for 6mm.. I don't have an ST FSM.... I'll check what's in the VFR manual....Uhhh, hang on a minute guys. You guys are quoting typical specs for the oil DRAIN bolt. He was asking for the torque for the oil PAN bolts. 6mm threads vs 14mm threads. Guess which is going to lose at 17-22 ft/lbs. I don`t have the manual near me, anyone else?
The oil pan information is in section 4 of the service manual - Lubrication System - page 4-9 in my copy. It quotes 12Nm, 9 lbf-ft. for the 14 oil pan bolts.
For reference, the service manual has 4 places where it may (or may not) show the torque values for specific bolts:
In my UK 2003-2004 manual, this starts at Page 1-12 - but later versions of the manual may be different.
- On the diagrams;
- in the text alongside the diagrams (usually in bold);
- at the start of each section of the manual;
- in Section 1 of the manual (General Information).
For others bolts that aren't listed, the manual says to use the standard torque settings - and shows the table below. This is from a 2003-2004 manual. If anyone has a later manual it would be good to see if they correspond !!
The torque settings are sometimes shown incorrectly in my manual, so it is a good idea to check all 5 places to make sure that they give the same figure. I have come across a few discrepancies over the years. Also compare the metric Nm torque setting with the lbf ft torques setting, to make sure that they correspond. The lbf ft value should be approximately 3/4 of the Nm value. Conversely the Nm value should be roughly one and one third time the lbf ft value (eg 9 lbf-ft = 12Nm approx).
