My ST has a small oil leak at the rear of the engine that will "dirty up" the backside, but never enough to drip. I recently changed the oil and spent some time cleaning it up. Shift shaft area, oil filter base, hose boss, and as far "up" as I could get. Here's the question....it is weeping and I haven't started the bike yet or moved it off the centerstand. Fresh, clean 5w-40 Rotella oil drool. What component lies below the oil level that could be the cause? It's NOT the shift shaft, gotta be something higher, but not above the oil level! Oil level right now at the exact top line in the sight glass. It's also spotless around the filter. Clutch fluid not going down at all, clean and reservoir full. Speedo sensor or clutch slave??
