Hi folks, very nice to join you all as a new member. I ride a lovely ST1100 ABS/TCS, 2000. Having recently put Diesel into her I have encountered a new issue as I've been trying to clear the diesel out. There is oil - not much - in the air filter and she is putting out plumes of smoke from both of the exhausts. There is a weak smell of oil in this smoke. The bike could be running 'fine' until I push along above 3600rpm and then after a while the smoke just bellows out BOTH exhausts. All four plugs foul up also. Before I go too deep into the carbs or valves is there a different solution? I suspect a blocked oil breather? Or, does the st1100 have a PCV valve? Thanks all, your thoughts would be hugely appreciated. Safe riding.
