Don B
The thread title says it all. Noticed it when I was doing my pre-ride check before leaving the house today. The high beam indicator stays on all the time the ignition is turned on, regardless of the dimmer switch position. I don't have any headlights, high or low beam. I know that I have seen similar problems posted here before, not sure if I have seen the exact same thing posted or not.
I know that for starters, I need to use some contact cleaner on the starter switch, since that may account for having no headlights at all, but I don't know how this might account for the indicator staying on all the time. The indicator does go off while the starter button is depressed. I'm also aware that I should check the headlight relays.
Is there anything that I'm missing?
