It will idle with without the choke on. When I apply throttle it dies.
I'm just wondering if my replys, comments or whatever you call them are being seen by you people over there. I've said check the earth wire specifically on at least two occasions and very early on in the discussions and it seems you never did it till now, that's why I'm wondering if you read them. Are you seeing them?..... Swede. (in Cornwall, England).UPDATE! Real progress made yesterday! I was trying to figure this out again and decided to have another go at it. I read through the entire post to see and if missed anything and then did some more searching to learn more about the ICM. I came across a thread from 2009 - called " ST1100 ignition problem NOT solved Yet!!" In that thread it had the attached picture of the wiring harness to the coils. I inspected mine AGAIN and could see no problems, but use my voltmeter to test continuity of each wire and connection and I found that the ground to (1/3) did not have continuity. I cut of the spade lug connector and crimped on a new connector and then I got continuity I needed! Put it all back together ands visible saw spark to all cylinders!
I said progress....but I haven't ridden it yet! Although the bike is running, it is running very rough my guess is that I need to tune the carburetors. I could get it to idle at about 1000 - 1100 rpm but when I try to apply throttle it would die. It acted a little better if I applied a about 1/2 choke and I could get the rpms up higher and then it might drop out. My guess is that it's running lean? Is this solved by synchronization of the carburetors or are there other things I need to consider?
Thanks to GitSum from the UK for this picture in the 2009 post and ChucksKLRST from Aurora Colorado who posted on the same thread that he had the same problem with a spade lug crimp connector. The weird thing is they posted Dec 21, 2009.....11 years to the day that found their post and solved my ignition problem.
And of course all of you in this thread who have been patient.
OK. Understood. I'll remember in future and try to give more info on how to do what I've suggested. Sorry! On the new problem, I presume that wasn't happening originally? I would strip and clean the carbs, removing jets to make sure they're completely clear and clean (blow with an airline) up the drillings the jets came out from. As its been standing for a while now, you may be having the 'ethanol problem'. Sometimes the ethanol leaves a residue in the jets so you can see through them but they are effectively smaller than they should be. Only way to clear them is to use a suitable size wire or better still, one of a set of jet cleaning wires. (get them on ebay)Hi Swede, good post.
Rest assured, I read ALL comments and try my best to follow directions. It's HOW to check, WHERE it is (often the close ups in the manual do not help), and in WHAT sequence. Specifically people how talked about "earth" or "grounding" here and finding there are all kinds of earth points on the bike at the kickstand, on the battery, at the coils, and on the fuse box...etc. It was only until I realized HOW to test a wire for continuity with a voltmeter did I realize my problem on "earth" not going through the wiring harness section that goes to the coil. First time I have ever measured "continuity" with a voltmeter....had to look it up!
I am a complete NOOB I have no experience with repairing engines much less motorcycle systems. Trouble shooting through this forum is way, way less than ideal but it's my only option right now. I'm surprised I've made it this far. I have learned so much based on the encouragement, especially when folks say don't give up.....your getting close!
I love riding and I love the way this bike rides, but I may have to accept the fact that I'm not a mechanic and I need to sell it as is and by a current model that can be serviced through a reputable repair shop.
Good ideas! Swede, I was real fortunate to meet "jrp" through this forum. He gave a long full day of his time to work on the bike since he has the same ST. That's the incredible thing about this forum. He checked out the fuel pump, changed the fuel filter, took off the carburetor bank, used a special wire to clean the pilot jets, inspected the diaphragms...and through the whole process cleaned everything, re-installed the bank after inspecting the boots......and had the patience to answer my constant questions. I then synced the carburetors....long day. Since then I've only put in non-ethanol gas.
I like the idea of "check all the airpipes" . I assume that means looking into the vacuum hoses that go to the carburetor bank? A lot a people on this forum have been suggesting a vacuum issue. I did a thumbs down to a $1,500 carburetor re-build offer. Maybe they didn't pay lot of attention to getting it back together right and just wanted to get it our of their shop at that point.
Dwably, your description is "spot on". It feels like it's a transition point from pilot to main jets. Sometimes I can apply fast throttle and make through the transition point and go up to 5,000 rpm but when I easy back on the throttle it drops through that transition zone of about 2,000 rpm then it dies.
Time to put this aside for the holiday.......Merry Christmas Everyone.
Although they are generally called 'idle' jets they do still play a part above that and I'd say the vacuum piston /diaphragm is probably only taking over about 2000-2500 rpm. Then, it's the needles rising in their tubes metering the fuel (the fuel is coming through the main jet but too slow for the jet to play a part). Then, when the needle is getting right up the flow has got high enough for the main jet to take over but, that will be at very high throttle opening and revs. That's basically how it goes. As you can see at about 2-3 thou up until the main jet it's the needle in the tube, that won't block but as its fed by the main, if that's blocked enough; or water in the bottom it could restrict the flow. Vacuum pistons could affect it at those revs too! Carbs can really be a pain, I think a strip down, close inspection to make sure everything is fitted back correctly and clear /clean is the way to go! If you're up to it, you've done well so far so you should be okay.... Swede.Good ideas! Swede, I was real fortunate to meet "jrp" through this forum. He gave a long full day of his time to work on the bike since he has the same ST. That's the incredible thing about this forum. He checked out the fuel pump, changed the fuel filter, took off the carburetor bank, used a special wire to clean the pilot jets, inspected the diaphragms...and through the whole process cleaned everything, re-installed the bank after inspecting the boots......and had the patience to answer my constant questions. I then synced the carburetors....long day. Since then I've only put in non-ethanol gas.
If you end up needing to go the route of carburetor rebuild, see this post.I did a thumbs down to a $1,500 carburetor re-build offer.
