Uncle Phil
First guess would be the non-firing coil is not got a good connection via the wiring harness - but that is a guess.
, Those results on the checking the sparks are exactly the same as mine were, except for being opposite sides. When I tracked down the cause and I found a resistance in that three wire connector, which joins the coils fly leads to the wiring harness, I knew I had got it. I cut the wires either side of the connector, even though it looked OK, and fitted in new individual terminals. I re checked the sparks and I'd got good strong sparks on all cylinders. I started it and it was obviously better. It revved quicker and felt good. Put all the panels back on, road tested and it was all good again. Did a round trip of about a thousand miles, didn't miss a beat. Do that connector, if only to eliminate it. If it doesn't cure it, check the connections on the ecu up front above the headlamp, on the coils and the earth lead connection which is down, close to the foot brake switch(I think). This is unlikely to be it though as it earth's a lot of other things as well as the coils and ecu. Good luck, let us know... Swede.UPDATE! I received the new coils and with great anticipation I installed them but now I'm stuck again and not sure of a next step.
Here's the facts..
1. (1/3) Measured the Primary Resistance of the coil through the 3P connector (yellow/blue) and black wire at (3.4 Ohms) Spec says 2.16 - 3.19ohms (out of spec)
2. (2/4) Measured the Primary Resistance of the coil through the 3P connector (blue/yellow) and black wire at (3.0 Ohms) Within spec from above.
3. (1/3) Measured the Secondary Resistance of the coil through the HT leads without the caps (14.93 Ohms) Spec says 13.5 - 16.5 ohms. Within spec.
4. (2/4) Measured the Secondary Resistance of the coil through the HT leads without the caps (14.53 Ohms) Spec says 13.5 - 16.5 ohms Within spec.
5. (1/3) Measured the Secondary Resistance of the coil through the HT leads with the caps (27.89 Ohms) Spec says 22.5- 25.5 ohms U.S. 22.5-27.5 Intl
6. (2/4) Measured the Secondary Resistance of the coil through the HT leads with the caps (2.27 Ohms) Spec says 22.5-25.5 ohms U.S. 22.25-27.5 Intl
So I had aha moment....the cap on the (2/4) might be bad.......so logically I took a working spark plug cap from the (1/3) side that was working within spec and moved it over to the (2/4) side .......it still measures (2.27 ohms). Hmm...not right....this makes no sense.
SO...I decided to get off the voltmeter stuff look at this from a more basic level. I attached a spark plug and did the "old school" test to see if I can spark by holding the plug in the cap and ground it against the motor. I turned on the power and hit the start button. On the (1/3) side I can see visible spark . On the (2/4) side I am not getting a spark....clearly not good. I made sure to take a spark plug cap from the now good (1/3) side to the (2/4) side...no spark.
I just don't understand why I am not getting the right resistance through from new coil, new HT lead, and a cap from the working side. Or for that matter no spark.
I was very careful to install everything correct an in the same way that the old coils were connected...however there were no markings on the spade lugs of the new coils. Does it matter how the power is connected to each spade lug on the coil itself? This is the two connector that come to the coil from the 3P connector.
Happy Thanksgiving,
Scott
Yes. Although mine looked OK, when I checked across mine it was showing a resistance so reducing the power of the coils but not necessarily cutting them out completely... Swede.Swede, is the logic to cut out the connector is because it may be preventing something from the main harness going to the coil?
Again, I assume you mean 2.27kΩ, but that is non-sensical because you can't make the resistance go down by adding another component into the path. I don't know how that could happen, so that's a mystery to me, but its something that you need to investigate further.5. (1/3) Measured the Secondary Resistance of the coil through the HT leads with the caps (27.89 Ohms) Spec says 22.5- 25.5 ohms U.S. 22.5-27.5 Intl
there's no polarity associated with the coil connector, either orientation will work the same.I was very careful to install everything correct an in the same way that the old coils were connected...however there were no markings on the spade lugs of the new coils. Does it matter how the power is connected to each spade lug on the coil itself? This is the two connector that come to the coil from the 3P connector.
I took Swede's advice and took out the 3P connector in case that was bad. In the process I took out the coil bracket with the coils and noticed one of the spade lugs to powering one of the coils was loose, perhaps I wasn't getting a ground to one side? Alas with high hopes I thought everything was going to work so after making sure all connections were tight I re-installed the coils. I took measurements with my voltmeter and found I'm getting the right resistance through the caps!!
Frustrated that the problem is still there despite all the measurements on the ignition system ( I'm wary now of what these measurements are really telling me). I pulled a spark plug on the 1/3 side and looked for spark....could not see one. Moved that plug to the 2/4 side and I could see spark.....SO my next thought was maybe I should after the caps. I have two on order. Hopefully that will be it....but a least if it does not work I will know that the ignition system is good and can chase down vacuum or other issues that my be suspect......TO BE CONTINUED
Sorry, they only serve yello jello there ...okay, I'm ready to go back to my room now... can we have jello tonight?
Would not syncing the carbs have revealed a problem with vacuum?
Hi @Ronn, I would normally think yes, but I had a vacuum leak on my ST 1300 that would not show up until the bike was well warmed up (about 30 Minutes). i chased fuel system and electrical for weeks. the problem progressively got worse as the weeks went by and replaced parts piled up. it turned out to be a vacuum line cap/plug that was cracking. after about $150 worth of replacement parts. plug wires, caps, fuel pump and filter, it turned out to be a $0.50 rubber cap on a 3 way vacuum fitting. right now
@ScottyG has better minds than mine helping him!
Surely you can just take the plug caps off, turn it over and see if there's a good spark? Then you'll know if the spark comes back, it's the cap, if it doesn't then the fault is further back.... Swede.I'm waiting to get a ship on the plug caps from PartsZilla, I'm sure they were slowed down over the Thanksgiving weekend. As soon as I get them I will be testing them and posting an update. All I can do it kick the bike when I walk by now....I sure hope I don't have to mess with the ICU or ECU unit. If it is as difficult to get to as the ignition coil I'm not looking forward to it.
Thanks all for "hanging" with me on this.
Scott
Just in case, the ECU is easy to access if it's the same as the st1300, it is located under the seat in the compartment just in front of the tail light. If not the same, someone will jump in with the location.I'm waiting to get a ship on the plug caps from PartsZilla, I'm sure they were slowed down over the Thanksgiving weekend. As soon as I get them I will be testing them and posting an update. All I can do it kick the bike when I walk by now....I sure hope I don't have to mess with the ICU or ECU unit. If it is as difficult to get to as the ignition coil I'm not looking forward to it.
Scott
Up the front, in the nose, on top of the headlamp.... Swede.Just in case, the ECU is easy to access if it's the same as the st1300, it is located under the seat in the compartment just in front of the tail light. If not the same, someone will jump in with the location.
