Ooops, now that I look at the part in the link you sent Darby, it looks like there is a coil for 2 cyclinders? So the ST1100 has two coils right? Remember I'm a noob.
Yes each coil fires two cylinders.Ooops, now that I look at the part in the link you sent Darby, it looks like there is a coil for 2 cyclinders? So the ST1100 has two coils right? Remember I'm a noob.
not only is it possible, if you read back on my various posts I've warned about it several different times in this thread.Is it possible with static testing things look with in spec but when the electrical systems is engage the coil doesn't perform or is intermittent?
Can one side of the coil work and the other side not?
that's what I was afraid of, I've never had to go in there myself, but hopefully others here have. The Honda manual says to remove the upper fairing, which I suspect involves removing a bunch of other stuff prior to that. I suspect you had good access when you had the carbs off, which now makes me think, is it possible you bumped something while working on the carbs that made the ignition condition worse?Tried to search the site for the best way to get in the replacement coil in there......no good pics in my Clymer manual. It's tight....any advice out there?
On the OEM coils there are probably plastic nuts that screw on where the wire goes into the coil. Try turning the nuts counter-clockwise and they should come off, but the wire will probably stay in place. After the nuts are removed, the wires should just pull out with a little force, and if you look into the hole in the coil where they insert there's probably a needle on the inside that is what makes connection with the copper core in the center of the wire.There's always a chance I could have bumped something. I'm new to this but trying to be thorough. I did manage to get the coils out through the top of the bike behind the Y of the handlebars. the power connectors and HT leads (BTW I don't know what HT stands for) look good on visual inspection. The mounting plate is completely our with the 2 coils. It looks the new coils come with the leads on them. I could not get the leads off of the old coils and since it appears to come with the new coils I'm not going to do worry about it. New coils have shipped and may be in by the 24th. Very, very hopeful this is going to be the fix
Jeff (jrp) from this forum was nice to take me under his wing to get my bike running properly and we spent a day a his place going through almost all the recommendations on the forum. Great guy and knows a ton and I learned A LOT. We did change the fuel filter, check to make sure the fuel pump was operating a spec, checked the gas cap, fuel quality issues, etc. etc. He then pulled the carburetor bank and check and cleaned the carburetor jets, inspected and cleaned the fuel diaphragms. etc. We then put it all back together and he showed me how to "sync" the carburetors....felt really good about after a long day in his garage....UNFORTUNATELY I left on the bike and not long after that the bike continued to act up.
I agree with this statement, but once again, reading what someone writes is a lot different than feeling/hearing the bike in person.Surging, to my way of thinking, is a fuel/air issue - carbs. Cutting out is not, that's ignition.
Check your fuel pump ?I recently purchased a 2002 ST1100 as a result of many of the fine comments on this board. I bought it with 36,000 miles on it and have put 3,000 of my own miles on it. I LOVE IT. I bought it for $2,500. The fun for value component is off the charts. HOWEVER, recently it starting developing a problem where the the bike surges forward without me turning the throttle and then sometimes it seems to have a drop of power like I'm riding a 350 cc bike. The hard part is I love to ride but have absolutely no experience with troubleshooting and even some of the most basics of maintenance discussed on this forum......so off I go to a Honda dealership hoping they can get to the bottom of it at a reasonable cost. As a start they check the plugs and coil and recommend replacement of the spark plugs and ensure that spark plug caps are rethreaded strongly to the coil wiring? They take for a test ride and feel everything is okay. When I pick up the bike and go for a ride the problem is still there. I call them and they say they will have to step by step go through the bike until the problem is solved. Makes complete sense....but given their labor rates, etc. , I could easily paying way more for trying to get this bike to work than what I originally paid for it. So I try to be smart and find one of the best independent shops around with more reasonable labor rates to give me a second opinion. He is Honda certified and seemed very, very, knowledgeable. He goes for a test ride and says he feels that the bike is dropping and running on 2 cylinder's and is very sure it is something in the electrical system. However he checks the coil resistance, spark plugs, and wiring harness, etc.......everything seems okay. After more head scratching, etc. he decides to look into the fuel system. Ultimately, he puts in Seafoam wondering if the gas in that tank is bad, etc. Take's it for a test ride and feel's it much improved. I pick up the bike, run another tank of gas through it and problem is way worse than before. Feeling brave after spending hours on this forum. I take off the plastic and look to do the fuel value vacuum by pass only to find out the that has already been done. It continues to run but it is super rough. If feels to me that it is a fuel delivery problem to the carburetors, but I'm TOO much of a rookie to attempt anything with them myself. In fact I'm amazed when some of say just pull off this and inspect and check this....I have no idea.
I interested in your comments and thoughts so I could a least talk the lingo with a mechanic to get to the bottom of this. Or did I make a rookie mistake in buying a 20 year bike when I don't have repair skills and perhaps I should trade in on something newer. I don't want to give up since so many times I have read on this forum of people who say they ridden 30,000 miles and all I have done is change fluids, tires, etc.
What to do?
Scott
