Jeff and I checked the fuel pump and it is pumping gas per spec. so I know it's not that. I guess I will have to take the spark plugs out and check them. I haven't done that because now I'm back to the beginning.........I posted this thread after the problem started and I first took it to the dealership. They put in new sparkplugs and test drove and said it should be okay. Of course, I took the bike and rode it and the problem was still there. This is exactly what they put of the notes in the work order ................ Technician wrote... "Was able to duplicate customers concern on the test ride. Feels like unit is dropping a cylinder. Found abnormal burn pattern on spark plugs. Removed small amount of coil wires and re threaded spark plug caps into coil wires to ensure positive connection. "
I took their recommendation to also install new plugs. I have no experience with spark plug caps or coil wires...so I don't know what they mean by re-threading.
I will do a visual on the spark plugs and search on how to test if if the spark is strong. I'm not too optimistic that there are the problem since they are brand new.
