aniwack
Name that code!
Here is a link that I was thinking about with the yellow connector. Take a look and see if this is an issue. Grounds seem to be a normal wiring fault it appears.Do you recommend removing the tank / airbox and checking inside of connections that may have been opened previously or checking for, or adding a temp ground to those sensors to see if that changes anything.
Well, if we put 5 Cardiologist in a room, we will get 5 different differential diagnosis. Fortunately with the ST, we limit the 5 down to 3 or less differentials, and most have some great though process that will lead to a positive outcome. Codes are just guidelines that may direct you to point to start IMO. Happy riding, not fixing! Isn't that why we chose to ride such dependable flavor of bikes?Don't know about @Youdooooooo but I can see I need to get heavy on codes, and their interpretation.
I read practically EVERYthing posted here, mostly on the 13s of course, because there may come a time when I will need to know.
Hope that time is many years from now...
