So when you mount the permanent heat troller...
lead from the battery or fuseblock connects via coax to the "box" which all ends up under the plastic, right?
-Hard mounted sead from the controller go to the battery or acc fuse block with the ring terminals.
The wiring that runs from the "box" to the dials is under the plastic to a location where you mount the dials (cut hole in side panel for instance - other locations?), right?
-I *think most people mount them on the flat surface just below the left front fairing pocket door. I'm pretty sure there is room for both potentiometers.
Then the coax lead(s) that run from the box that you plug into your gear is run to a location where it comes out from under the plastic, right? Typical location?
-usually just snuck out from under the seat. close to where the jacket liner lead hangs out while you are sitting on the bike. (behind your leg)
I had been leaning towards the portable troller for no other reason other than I didn't really want to cut holes in my panel, but for $70 and then a closeout Gen 2 jacket for $99, I'm thinking that is too good of a deal to pass up...
