I have one and have tried it a handful of times. I find it sucks air around the loose bleeder so you can never get an air-free "pull". I tried removing a bleeder and applying teflon tape to help seal the loose bleeder... what a mess. I will still use it to help evacuate old fluid out of a system and when I get to the fresh fluid, I remove it and resort to the traditional "pump and bleed" setup, with a one way valve. I use the vacum pump as an aide only because I bought it and have it. If I knew then ( when i bought the mityvac) what I know now, I wouldnt have spent the money on it. It does have other uses, which you may or may not need... e.g. it can test vacum operated valves and switches for leaks and operation. I have used it a couple of times for that. I set fork oil level with a metal tube with a stop at a measured graduation to get the level exact in each tube and it is quick to suck old fluid out of master cylinders before filling with fresh stuff to bleed with.
