I have been working this problem for a while and have not corrected it. My 2005 ST started giving me a code 26 on the F1 lamp. I went to the service manual and it indicated a malfunction with the right knock sensor.
I performed the first part of the diagnostic to determine if the sensor was at fault. I found some information on the manual that did not make sense. It tells me to look for continuity between the knock sensor wire and a terminal at the computer. If there is continuity, that there is a problem with the harness. I went over the wiring diagram and found that there is nothing in between the sensor and the computer, so if there cannot be any continuity; how does the knock sensor communicate with the computer?? Nevertheless I did find continuity, so in my brain I was satisfied with my analysis, not Honda's.
Since the connector at the knock sensor broke in my hands while removing it, I thought that it could be the problem. I ordered the knock sensor and the partial harness (major pain to install, about 6 hours). After installing the sensor and the new harness section (the one covers both knock, oil pressure, temperature sensors and the neutral switch).
I went riding and the light came back on. I had forgotten to re-set the computer, so this must be it. I proceeded to re-set the computer and went riding again last weekend. My F1 lamp came back on!! Needless to say I am very frustrated with this. Furthermore I cannot ignore the lamp while riding, not to mention the decreased performance and additional fuel consumption I'm getting.
Any suggestions??
Jeff
Any suggestions??
Jeff
