If you don't know, you should: your Honda does NOT use Phillips screws. Those cross-point screws are JIS (Japanese Industrial Standard.) They look virtually identical to a Phillips screw/screw driver, but are fundamentally different. Phillips screws are designed to have the screwdriver "cam out" (aka slip/strip) when the fastener reaches a certain amount of torque. The JIS screws/screwdrivers are designed to NOT cam out - and require that the person limit the torque on the fastener.
Inevitably you use your Phillips screwdriver on your JIS screws and they strip out because the screwdriver is designed to do that. If you use the proper JIS screwdriver you are MUCH less likely to strip a screw.
About six months ago I bought my first JIS screwdriver - from Vessel (a premium Japanese brand) and it included an impact driver built into the handle. The tip is a #2 which will do most all the screws on your bike. I couldn't believe the difference in using this screwdriver (especially on carburetor bowl screws) compared to my old Phillips screwdrivers.
This week I bought a new $15 Vessel 220W Ball-grip screwdriver with replaceable tips in #1, #2 and #3 sizes along with a flat blade that fits beautifully into jet slots and bowl drain slots. It was $15 via amazon and although I wish it were an inch or two longer, the hex shafts allow me to slip a wrench on to add torque for the tough, large screws on the carb rail of the CB750 I'm working on. It's solid and well built and I wish I'd known about JIS screwdrivers years ago!
Recommended: https://www.amazon.com/gp/product/B00E55DL4I/
