Pop-Pop
May you not need the 15 deg part, if you find 40 though, you will be happy you have it. You're out 8 hours and I'm already jonesing.i bought a 15 deg down agnes, and a 30” klymit static v insulated pad!
Gotta get that fix on rt 66!May you not need the 15 deg part, if you find 40 though, you will be happy you have it. You're out 8 hours and I'm already jonesing.
Have i mentioned how bad assed my ambers look? Folks can see them well in their mirrors
Amber is Good. But, what works best is alternating blue and red.![]()
Following along. Wishing you good weather and safe travels.
IINM, your tankbag is a 4 point, and sloped/slanted. I recommend you simply rotate it 180° so the front of it is now higher than the rear. Makes reading the map easier. BTDT with my waterproof Wolfman bag many, many miles ago.
Who is the manufacture and what is the model of your fork mounted lights (yellow ones) as they look like they would be a good addition, and they look smaller than what I have seen others use.
Hmm…. the map pocket on the Wolfman is excellent, I have not noticed glare except in very rare circumstances. I am short though, was 66” at one time, then less, and now back up to 65” after some donor bone during cervical fusions. Might make a difference, dunno.I tried that and got a lot of sun glare, and i dont wear sunglasses. But, because you suggested it, ill experiment
There you go! Ill be just outside of chicago tomorrow getting ready for the morning start at rt 66Hmm…. the map pocket on the Wolfman is excellent, I have not noticed glare except in very rare circumstances. I am short though, was 66” at one time, then less, and now back up to 65” after some donor bone during cervical fusions. Might make a difference, dunno.
Here I am heading to a week of canoeing and fishing in the BWCAW at the MN/ON border.
just go to the mens room once in a whilemake sure my boi-hazard suit isn't leaking.
ah duh... that's why I check for leaks..just go to the mens room once in a while![]()
ah duh... that's why (how) I check for leaks..
