My NH750 tubes were physically perfect when I restored them with the super-glue, no buffing, just a blade.Added tip: if you sand/hone/polish do so circumferentially in a shoeshine motion, not parallel to the tube. BTDT Longitudinal scratches give the suspension fluid a path across the seal.
The fingernail test is a good test.
its about 10 cm above the fork seals and deep and rough, I can easily feel them with my finger let alone my finger nailHow high up on the fork tube is that? Looks almost like specks of road tar. Try wiping them down first with acetone or similar solvent. If that removes it then just "polish/buff" with fine emory cloth.
Be sure to keep the blade parallel to the tube, so the blade doesn't cut the top of the fill concave.Thankyou for all the suggestions, I am going to try the dental pick then solvent then super glue approach and will report back how it works
How long did you leave the super glue to cure before using the blade to smooth it ?My NH750 tubes were physically perfect when I restored them with the super-glue, no buffing, just a blade.
The pits and, to a lesser degree, the longitudinal scratches are still visible, but you can not feel them.
I honestly don't remember, but what I did was find several different sites with posts and threads on the process, and formed anHow long did you leave the super glue to cure before using the blade to smooth it ?
