I haven't seen any threads comparing pics of brake pads.
Since the EBC use the same part numbers for the front and rear pads while Honda has different numbers front to back, I thought this would be interesting...well, a little at least.
Honda rear pad compared to new EBC
(I haven't compared the front Honda pads to the EBC's yet)
I thought I needed new rear pads because the piston was extended rather far and the leftover pad looked low.
Here is my well worn pad and the new pad (still in packaging). Not too different in pad material (So I kept the old pad in the caliper)
Even the OEM Honda backing was beefier
One thing to double check before walking away is the pad "seats" into its slot on the caliper. I mention this because you can STILL install the allen bolt to hold the pads through their tab holes when the pads are NOT seated. This is a photo from the opposite side, peeking through the wheel. Note the pad tab is fully inserted into the caliper.
BTW, should I keep the HH pads or go to Honda pads?
![S5001295.jpg](http://img.photobucket.com/albums/v231/asrstech/2005%20Honda%20ST1300/S5001295.jpg)
![S5001297.jpg](http://img.photobucket.com/albums/v231/asrstech/2005%20Honda%20ST1300/S5001297.jpg)
![Hondabrakepadcomparison-1.jpg](http://img.photobucket.com/albums/v231/asrstech/2005%20Honda%20ST1300/Hondabrakepadcomparison-1.jpg)
![Hondabrakepadcomparison-2.jpg](http://img.photobucket.com/albums/v231/asrstech/2005%20Honda%20ST1300/Hondabrakepadcomparison-2.jpg)
![S5001299.jpg](http://img.photobucket.com/albums/v231/asrstech/2005%20Honda%20ST1300/S5001299.jpg)
