I have a 2001 UK-spec Honda ST1100A and am experiencing issues with the headlight. The sidelights and high beam function when using the passing/flash switch, but the main lighting switch does not activate the headlight. I have checked all fuses and bulbs, which are in working order. We have traced the wiring from the handlebar switch to the joint under the airbox and are now attempting to locate the headlight relay for further continuity checks. However, we are having difficulty finding the relay. Although I have the Haynes manual, the wiring diagram colors do not match those on my bike. Can anyone provide guidance on what else to check, the exact location of the headlight relays, or a correct wiring diagram?
