peterz
I know i have seen this before but can't seem to find it . Anyone have a part or SKU# they can help me with?
Thanks
Peterz
Thanks
Peterz
For the later model, Zumo's the cradle and hard wire kit come with it. I have two of them.I have not seen one for a Nuvi, but for the Zumo, there is a way to hardwire the OEM cradle. Basically, you open the back of the cradle, follow the incoming cable where its sheath has been removed, and clip all the wires except for the red and black. Slit the sheath of the cable outside at the length you want and pull those colored wires out, leaving the red and black. Now cut the cable off leaving a few inches extra red & black wire. You will now wire these to a connector or male powerlet plug or cigarette lighter plug. The colored wires you cut and removed were for aux speakers and other comm gear. If you think you will need them, don't do this - a new cradle sells for around $60.
As stated by others, the Nuvi's washout in the sunlight and are not waterproof. I have a 2795 and a 2895 Nuvi, both have been used on bikes as well as in the cage. They work well in the car, but not well on the bike. I used a USB adapter to power mine on the bikes. I know it hurts, but the Zumo's are made for the bike and you can see them well in the bright sunlight. They are also waterproof. Different models have different features. I have a 396 for my ST and a 390 w/TPMS for my Goldwing. They work very well.Nuvi 2595 It's a old one but i am going to upgrade sometime.
Yes, it does matter. Here is the mount and wiring kit for the Zumo 396. It has a special connector that contacts a set of pins on the back of the device to connect power and allow quick release. I cannot find anything like it for a Nuvi. https://buy.garmin.com/en-US/US/p/pn/010-11843-00 https://buy.garmin.com/en-US/US/p/pn/010-11843-01I don't think it matters what model you have as long as i can power it up with the wiring kit.
Absolutely true.Zumos wash out in the sunlite also. I have a 660 and can't see it half the time due to washout.
Don't have that problem with either of my Zumo's. Do they get a little dimmer in bright sunlight? Yes, but I can still see the maps.Absolutely true.
My 665 is useless when the sun is out - and I have a windshield on it.
I wonder if the screens lose brightness as they age ?Don't have that problem with either of my Zumo's. Do they get a little dimmer in bright sunlight? Yes, but I can still see the maps.
