I've been working on my brother-in-law's new project a '91 Nighthawk 750. Turns out the carbs needed a good going over, and fuel rubber bits replaced - needles from K&N, float bowl gaskets, and fuel rail o-rings from... Harbor Freight.
The most recent leak we found was after putting the bodies back together. Leaking from the fuel pipes that join the bodies. The o-rings had given up the ghost - no more squish left to seal. Quick shopping around town and Harbor Freight sells a 200 piece of assorted Nitrile o-rings in Metric sizes for a whopping $5. Reassembled filled with gas, tilted this way and that, and no more leaks. Highly recommended you add this to your garage. I'm planning on replacing the oil cap o-ring on his next.
