v8-7
Background :
I have a pretty standard setup : 5KW generator that plugs into my house through a l14-30 cable into a plug on the side of my house, wired to my circuit breaker box through a40 amp breaker with a manual operated lockout type transfer switch.
For years my neighbor has also been plugging in an extension cord . to run 2 refrigerators
He is now getting a 14 KW unit and has offered to let me plug in to his house which would be from the time the power goes out, until I get my generator running. Usually the next morning.
So basically , when a storm is coming in, I would be plugged into his unit and would have some power, typically from the evening when the power usually goes out , until the storm has passed and I would set up my own unit.
Rather then using an extension cord to power just a few items, what I would like to do is cut the end off the extension cord and wire an l13-30 plug onto the end and plug that into my house .
That would only be one leg of the 220 feed ..
So I think I would be powering one side of the circuit breaker and all circuits on one side would have power, and the other side no power .
That would work for me as all the circuits I would want to use are one 1 side of the box except for 1 which can be easily moved.
Is that how it would work ?
I know I am plugging into only a 15 amp circuit and would have limited power.
Thanks, Stan
Thanks, Stan
