jfheilman
Say,,, that looks a lot like my discontinued Zumo 550 mounted on a special mount in my discontinued 1996 Ford Explorer.
I create all my routes on my computer.Have you tried to make routes on the screen? If so, try to convert via points (orange dots on the left of address) to Shaping points (orange dots becomes blue dots) and check the map again if the shaping points moved from their original locations (where the via points were) to a different spots on the route.
Traffic is included at no cost on the 396 LMT-S and the weather was a one-time payment of $5 I think, but I would pay that (or more) annually for both if I had to... weather and traffic can change quickly on long trips. Of course neither is perfect, so a phone check at fuel stops is helpful verification.I can look at the Zumo when I need to, it's in my line of sight, but I don't have traffic / weather on the Garmin -- is yours subscription based? I'm too cheap for that.
FWIW, I create routes on my computer (Basecamp) for rallies and directly on my 396 for basic trips. It's not too bad doing it directly on the 396, as long as you zoom in enough. It may be even easier on the XT.I do too. But looking for ways to save time of creating, download, load to nav... Also sometimes you're in the "field" and need a quick route.
Agreed, Garmin is far from perfect, but there's an option to skip the next waypoint, or you can edit the route and delete waypoints.Yes, it's easy enough on the 396 too. However the software is not intelligent enough to leave the last point so you could continue from there and not guessing where you put it last on the map. Garmin is not perfect
So to use the vertical mode do you have to mount the cradle accordingly? No way to put the cradle on a RAM ball?You can't rotate the XT without rotating the cradle with it..... 'spose one could rig up a pivoting mount, but that would take some thinkin'.
I don't know how you do it. When I'm riding along and don't have GPS directions in my headset I ALWAYS miss a turn. Most annoying. I get distracting thinkin' about things, you know?I seem to be in the minority here, but I never use my GPS for music or connect my Sena to it, which seems to eliminate (for me) many of the phone/GPS/headset connection problems I read about on several forums. I do connect my phone to my 396 GPS for traffic and weather, but I don't connect my Sena headset to it. Phone to GPS for traffic/weather and Phone to Sena for music/calls works really well for me. Seems adding the GPS in between for music just makes it more complicated? Am I missing something? FYI, I don't need or want to hear my GPS directions in my Sena.
I used to use my GPS horizontally too. I've since changed to where almost always now, I use my GPS vertically. In a horizontal mode, you see out to the sides a lot. It's interesting and pretty, but I'm going forward, not sideways. In vertical mode, I'm looking at where I'm going. On the Zumo XT, the difference if you have one of the info panels up, is not that much. But have just the map displayed, and the difference is huge. Both will cover about the same distance...but the vertical mode is not as compressed and you can get more detail at a glance.I don't know what's the point of mounting it vertically. Even if navigating on a phone I mount it horizontally.
Tried again and screen came alive but said low battery. Charged it over night and still the same.I realize that this is opening a big can of worms, but.......
If you can't get your unit repaired economically, don't discount switching over to a smartphone of some sort. Lots of inexpensive options available. Along with that are several GPS programs that work just as good, or better than Garmin and the bonus is you are not married to Garmin.
Lots of info here
Or even Osmand. Being tied to Garmin's maps, to me, is quite a drawback in this day and age but I imagine it is quite a revenue generator for them. Interesting that the "lifetime maps" thing is for the life of the unit, which Garmin can arbitrarily determine.If only Garmin could use Google's mapping platform
Good luck.hope that fixes it
ALL this.In vertical mode, I'm looking at where I'm going. On the Zumo XT, the difference if you have one of the info panels up, is not that much. But have just the map displayed, and the difference is huge. Both will cover about the same distance...but the vertical mode is not as compressed and you can get more detail at a glance.
I have a Zumo 600 still going strong from 2009, not looking forward to the day it diesAfter 6yrs my garmin 660LM died during my last ride. Not sure it can be fixed.
If not,
anyone having luck with 395 or 595.
I store music on it also. Don’t think car ones do that.
recommendations welcomed
