2009 ST 1300a
I'm asking for help to make sure I'm going in the right direction before I pull/replace the fuel pump.
The fuel pump is not working.
Does not momentarily run when the ignition is turned on.
I read and used an extensive write-up on how to check the relays, bank angle sensor, ect., ect. Attached. (Thank you JF Heath, from Australia I think, and ST-Owners.com).
Everything seems to be working as it should. ( I must note I am not a pro at checking electrical components, but not ignorant either.)
When I check the power at the three prong plug that goes to the pump I find this:
Right prong is Ground, and it is grounded.
Center prong: I get 11.19 volts when the ignition is on.
Left prong: I get 12.04 volts for maybe 1 second when the ignition is switched on.
It seems to me the electronics are working and the problem is the pump.
Does that sound right to you?
If you have any advise or tips or anything please let me know.
If you have any tips on replacing the pump please let me know.
The entire pump assembly from Honda is expensive. I've seen threads where just the pump can be replaced. If anyone has any experience with replacing just the pump I'd sure like to hear from you.
Thank you.
Thank you.
