so now, what is the difference between and E-bike and an electric motorcycle? Both have electric motors. So therefor an electric motor cycle should be able to use the bike path as well as the E-bike using the street. Just asking.
Pedals is part of that equation.
A sub part amongst the e-bikes is that if one can push a button to have the motor propel you without pedaling, the e-bike is limited to a top speed of 20 mph.
If pedaling is required to propel the bike, that is, electric assist only operates when pedaling, the top speed is limited to 28mph.
I don’t know how the lobbyist and law makers came to this conclusion and never got a clear answer, but it might be a safe guess that some physically fit bicyclist law makers realize they’d like a 28mph e-assist bike being offered while at the same time recognizing that someone that can barely pedal 10mph may also be the type that doesn’t have the reflexes to handle 28mph.
I sell bikes with Yamaha motors that are run through a program to give a very human feel to the assist regardless of assist level.
The gain in effort you put in is more directly equated with the gain in assist.
People first thing would turn the gain up all the way and take off half out of control.
We changed the introduction of test rides to start with no assist then add more as you go to experience the full range of capabilities (keep you from hurting yourself).
The gain on some e-bikes is way high right off the line, presumably because this will impress the customer with how powerful the motor is even when the assist level is set low.
I have seen a number of mature customers not buy bikes set up this way because it is unsettling.
After writing all that I went back and got the fun part of your post.
