Progressive fork springs are usually wound with more turns per inch at one end than the other end, but the ID and OD of the spring coil is uniform over its entire length*. These springs are unconstrained over their length in the fork tube, i.e they are dropped into the fork and sit on the valving at the bottom while the other end (slider) is capped with a preload spacer. Inverted forks will have these parts reversed.
So why do manuals usually tell one to insert the springs with the closely wound coils down (or up)? It should make no difference at all which end of the spring is down. Force applied to either end will flex that part of the spring where the resistance to bending is least, regardless of position. What am I not considering?
*Even if the spring were wound with differing diameters, as long as the spring is constrained only at the top and bottom it should not matter which end goes into the fork first.
